Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning
We compared price of Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning across hundreds of online stores. We found Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning in 1 store with lowest price $3431.93 in Bellacor. For detailed price comparison of Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning check table below.
Merchant | Price | - |
Bellacor | [show price] |
Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning description from Bellacor
- Galveston Semi-Cassette l Right Motor with Remote Retractable Awning - Manual over-ride motor with remote control. Left motor when facing the awning - 20' wide x 10' projection or depth with adjustable pitch - Multi chamber arms with stainless steel cables - Aluminum frame, powder coated in white - Fade, mildew, water resistant 100% solution dyed acrylic fabrics - 10 Sahara style valance with off-white trim - Fully assembled, ready to install and comes with the wall brackets - 5 year limited warranty - Product Depth: 120 - Product Width: 240 - Product Height: 10 - Product Weight: 199 - Material: Fabric - Minimum Mount Height: 96-in - Minimum Required Clearance: 10-in - Includes Fully assembled awning, product manual, rocker arm, wall mount brackets, and remote control Awntech Corp - SCR20-17-GW
Customer review
Stop buying oher cull. This is the one and true quality Galveston Gray and White Semi-Cassette Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning. That you might have at best price in the whole internet. Lets buy it from this Bellacor and you will see the difference.
