Maui-LX Burgundy Pin Left Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning
We compared price of Maui-LX Burgundy Pin Left Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning across hundreds of online stores. We found Maui-LX Burgundy Pin Left Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning in 1 store with lowest price $1867.93 in Bellacor. For detailed price comparison of Maui-LX Burgundy Pin Left Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning check table below.
Merchant | Price | - |
Bellacor | [show price] |
Maui-LX Burgundy Pin Left Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning description from Bellacor
- Beauty-Mark brand Maui-LX model motorized retractable awning - Manual over-ride motor with remote control. Left motor when facing the awning - 16' wide x 10' projection or depth with adjustable pitch - Multi chamber arms with stainless steel cables - Structural steel and aluminum frame, powder coated in white - Fade, mildew, water resistant 100% solution dyed acrylic fabrics - 10 Sahara style valance with off-white trim - Fully assembled, ready to install and comes with the wall brackets - 5 year limited warranty - Product Depth: 120 - Product Width: 192 - Product Height: 10 - Product Weight: 154 - Material: Fabric - Minimum Mount Height: 96-in - Minimum Required Clearance: 10-in - Includes Fully assembled awning, product manual, rocker arm, wall mount brackets, and remote control Awntech Corp - MTL16-170-BPIN
Customer review
Something still missing. This is not my best awnings.
